1 - 2 of 2 Posts
I tried to look for a similar thread but didn't see anything, so I apologize if this is a cross post.
I have a Titanium hatchback with the 18" wheels, and I've read in other threads about how Ford boosted the trunk flooring up with foam supports to leave room for the larger spare wheel. First of all, I'm not even sure the spare I have is larger than a donut. But I've also noticed that there's no support on the outside edge of the floor, and if I put anything with a little weight on it, it starts to cave. Has anyone else had this issue, and is there anything you've done about it?
Whatever kind of wood/plastic that's stiff enough & easily cut to fit for under the carpet works. Need at least two pieces, one for each side, so it can be installed/removed easily. (single piece the size of the trunk floor couldn't be installed/removed)
1 - 2 of 2 Posts
