Symptoms started when I went to shift into 3rd one day, wouldn't go in at all. Limped the car home having trouble getting into all gears unless at a complete stop and even had a little trouble then.
Sitting still it shifts fine if not a bit notchy occasionally locking out of 3rd or 5th, not much difference while running or clutch in or out.
I went through the cables and linkage, all is good with them. I can replicate 3rd and 5th lockout with the cables disconnected sometimes.
I bled the clutch, no bubbles. I also flushed the trans and noticed no shavings.
Clutch does not slip although engages fairly high. Tested clutch with parking brake on, car stalls in 1st and 4th with minimal slippage.
I am suspecting clutch does not fully disengage, I can get in gear if I rev match and pumping clutch makes no difference. Should I go ahead and replace the master cylinder even though it's not leaking?
I am almost at whits end with this car, hoping someone can provide some insight.
Thanks in advance!
Thanks in advance!
