1 - 6 of 6 Posts
Hey,
I was wondering what I should use to cut the seal on the top of the volant. I got it on after a good deal of effort but the thing they sent me is a couple inches longer than what I need.
The rubber isn't the issue, it is the plastic lip that is.
box shouldnt be longer check your install, did u remove the bottom half of the stock air box? volant made all the boxes the same and all zetecs are the same under the hood cept for with or without insulation
Mr. Wizard
he means the rubber surround peice that goes on the top opening, yeah, mine was long by about 2 inches, probably so I didn't get shorted. You'll need a pair of snips, since there is a tin piece in the clamp part that you need to cut, I tried with a Razor but that only got me down to the tin, had to cut it with some snips. Have fun.
Discussion Starter · #4 ·
Yeah I'm talking about the thing on the top of the box...
Okay RPIJG, I'll give that a try when I got from work.
Discussion Starter · #6 ·
yeah, tin snips worked like a charp... I got the thing in, I'll put up pics as soon as I get the film developed. I even got pics from the g2g I went to today. [:)]
1 - 6 of 6 Posts
