I have a 05 2.0 automatic focus. I had my transmission in for a fluid change. The next day I noticed that the transmission now is slipping and there is a long delay between shifting from gear to gear before it engages. I stopped and checked the fluid and it was about 1.5" over the max fill level. I called the shop and took it in to have the fluid removed. Now with the fluid level where it should be. but it is still slipping and having engagement problems. I told them this and they said there must be another problem because there is a breather so that no harm will come to the transmission from overfilling. Is that true? In the manual it states that this is what happens when you overfill the fluid and major damage can result. I'm thinking that the transmission shop is responsible for the damage. What do you guys think?
