1 - 13 of 13 Posts
I need BOOOOST!!!!!!
are there any other transmissions that can mate up to the 2000 year model zx3 focus? i know the mtx but i would really like a 6 speed close ratio. would the svt tranny mate with the zetec engine? im not looking to do any extensive fabrication work so the rwd conversion is out guys, sorry. i dont make THAT kind of money. if there arent any 6 speeds that work then what is the difference between the stock zx3 tranny and the mtx-75?
Shot me 3 deer!!!
but its not a direct bolt up. you need a new flywheel and also the shifter cables and other parts. not cheap.
FUBARCUS
2003 ZX3 2016 FoST
There is a guy that did this search for it I know its on here I just remember where. I asked the same question. Actually that is why i joined this forum.
Shot me 3 deer!!!
its under the transmission section. there have been more than one person that have successfully done it.
  • Like
Reactions: focusmaniaczx3
Discussion Starter · #6 ·
any way so there are no 6 speed transmissions out there that can just directly bolt up to the zetec and the mtx-75 is the stock transmission correct?
Shot me 3 deer!!!
correct. you have to do an SVT getrag swap.
Discussion Starter · #8 ·
thank you very much sir rep where it is due
The SVT 6speed is not a great choice as if it breaks, you are looking at a very big bill to replace the whole tranny if you can find one. No one makes parts for it.
The MTX is a very good tranny, and parts are readily available.
Mtn. Dew
It IS a direct bolt up. Yes you need a new flywheel. That doesn't change the fact that the tranny will bolt right up. It could be done cheap, depends on what you pay for parts.
Shot me 3 deer!!!
i took bolt up to mean just pull the tranny off and put it back on. there is more to it. i mean, ur cables, shifter, flywheel all need to be swapped. its not like putting on an aftermarket wheel.
FUBARCUS
2003 ZX3 2016 FoST
Not to mention you have to get the shifter its not cheap per say it like 2-3k atleast that's what it looked like it would cost when I researched this. Decided against between money and practicality. Also the mtx-75 is better in a straight line.
1 - 13 of 13 Posts
