hello everyone, im new here, looking for desperate help.
i own a 2010 focus se 2.0 automatic.
i purchased this car from a salvage auto auction online. The car had damage to the rear passenger side, which will required some body repair, and some rear suspension repairs. This is however the least of my problems.
Main issue is the transmission does not go into any gears. Here's what ive done so far.
Tested shifting to all gears, no transmission response.
removed shift link from tranny, manually shifted gears @ transmission, still no response.
Tranny oil level is good, oil looks clean and doesnt have a burnt odor. tested Neutral safety sensor, works perfect.. only starts in P and N.
transmission has 2 electric plugs in the front top of transmission.
1 leads to the Neutral safety sensor, and another to something else, that im not sure what it is. checked both connectors for power, tested ok.
I also unplugged the sensor located at the rear top of transmission which i believe is called shift speed sensor. checked that cable for power. did not have any power at either pins. not sure if it is supposed to have power there, or maybe my tester doesnt register if its really low amp.
not sure what else to test at this point. Any help would be GREATLY appreciated.
Again car was purchased at a salvage auto auction with damage to the rear.
Car only has 73k miles. Car does start, and engine sounds really good.
Not sure if car was running at time of impact or not. (i would assume so)
I have a feeling the problem may be electrical or sensor/relay related, as doesnt shift into any gear, doesnt make any strange noise. fluid doesnt smell burnt,and is fairly clean, no signs of metal residue.
no check engine light. also checked fuses in instrument panel. fuses are good. did not check relays, not sure if one can be related.
thanks again.
thanks again.
