1 - 2 of 2 Posts
My transmission had been slipping a little bit before the overdrive is off light started flashing followed by the check engine light. I took it to autozone to see what code it was flashing and it said solenoid a was stuck. Since then ive changed solenoid A, Solenoid C, changed transmission filter and fluid and notging has changed. Any suggestions?
Wiring bad to the solenoid will make it seem to be stuck as well. Could have mechanical problems in trans too, computer cannot deduce that, only point to a controlled part that does not seem to be working right. A human brain has to sort the true problem out there.
1 - 2 of 2 Posts
