21 - 29 of 29 Posts
No slave included with this particular one because it was taken off of the Massive race car after a few passes, sent to clutchmasters for rebuilding, resurfacing and a new friction plate. Are you talking about the slave cylinder?
Sent from my Z981 using Tapatalk
Old Phart
Looks like you found an excellent deal for the long run, doing the work for only a master cylinder is counterproductive when not essential.
To add another item, crank bolts are recommended when replacing a flywheel.
Old Phart
I don't remember them as TTY bolts, normal torque specs IIRC.
2.3 length required unless something different is suggested for that flywheel (2.0 are different).
Ordered some ARP 12 point flywheel bolts today. Gotta figure out the size I need though so I can get the right socket.
Got the luk clutch. Looks really nice. Not quite sure how the bleeder functions. But I love how the center of the shaft looks like you can take the top assembly off if it breaks without having to take the transmission out.
21 - 29 of 29 Posts
