my clutch went out. i got a new oem replacement, that slipped a little so i got a clutch master kit (07-169-hdtz) and put on a fidanza aluminum flywheel. i put a new slave cylinder,and master cylinder.pedal free play checks out. had to have the flywheel machined down (done). still acts like there is no clutch. act like its in neutral. transmission? it sounds like it is shifting into gears but just not hooking up to spin the wheels. when trans was out i could turn the drive shafts and both sides turned. IDK?!?!?! any ideas? thanks
