1 - 3 of 3 Posts
I dropped the trans pan on my 06 2.0, auto and changed filter, how much fluid does it require to fill to max level? Seems like I'm going to overfill with my dipstick readings... thanks...
just dropping the pan i think is somewhere around 3l. just measure the fluid you took out and put that much back in and check it after driving for a few min
If you drop the pan you then add 3 quarts, however you also want to then remove the return line and pump one quart out at a time. I think the tranny holds 7 quarts
1 - 3 of 3 Posts
