1 - 4 of 4 Posts
Okay my advance trac light is staying on now all the time . It used to be if I drove the car hard it would come on . Now it won't go off and there are no trouble codes . Could it be a bad switch ? need to know what to do Thanks
DTC P0606
The traction control light comes on permanently to indicate that there is a fault in the system and the system has been turned off.
The usual problem on older cars is the wheel speed sensors or wiring, I've read. One or more need attention or replacement.
Did you have a diag ran on the ABS system? Thats the place you will find any errorcodes related to the traction system.. By default the traction is enabled (light off) every time you switch on the ignition, I will try on my car tomorrow, keeping the switch depressed when switcing tne ingition to on, and see if the light stays on.
Tried today, if the switch is broken (ie always "pressed"broken)the traction light will stay on when you switch ignition on and its not possible to switch it off..
1 - 4 of 4 Posts
