This^^^^^+ When you turn the ignition to the on position does the t/c light on?Simple go over some bumps or water on the gas see if traction kicks in. Then you know its just the light.
No, the light doesn't.This^^^^^+ When you turn the ignition to the on position does the t/c light on?
I haven't noticed the ABS light, but I believe a few lights maybe burned out, or missing. I'm going to pull and replace light bulbs tomorrow. Where should I be looking for these lights, in case they are just burnt-out?The TCS and ABS function from the same module, does the ABS light come on when you turn the key?
TCS is below the temp and tach/No, the light doesn't.
Also, I've checked the fuse, and it's there, I'll pull the fuse tomorrow when I've got my Leatherman handy, and check and replace if necessary. The previous owner did the fog lights mod, so I'm wondering if he disabled the tc or something as well. There's some sort of power switch along with an aux jack, on the dash that I have to chase down and figure out what it went to.
the ebrake light is lit, but the other 2 don't light up at all. I'll have to go and replace all the bulbs. I grabbed a bunch from a pick a part the other day. I'll try them out, and see If that helps. If nothing else, I'll swap them out, with bulbs I know are good, like my seat belt light, and see if they light up.TCS is below the temp and tach/
If the fuse was blown or missing then the TCS ABS (and brake!, I think) lights would be lit.
