1 - 10 of 10 Posts
i went to the my ford focus site to read up on how to install tb
i see the holes just wondering if the 02 hole is the same for 03 hole?
are there alot of people gettin the engine light on by replacing the tb or are they gettin the light on cuz they fuct something up while puttin it on or just a leak? how tight should i tighten the screws?? dame plastic intake dont wanna fuct it up!!!
thanx
-danny
FF #1 Most Wanted
If you look at the stock 2003 TB, you'll notice that the TPS mounts are at 6 and 12 o'clock.
So, you need to used the same 6 and 12 o'clock mounts for the TPS on the 65mm TB.
The 2003 TPS uses the 02 ATX mounting points on the pic.
***You'll notice that there is no 2003 or newer markings.
FF #1 Most Wanted
The stock 2003 MTX TPS screws are too big. They will only fit in the 02 ATX holes.
Also, click on my profile and look at my homepage link. There is a picture of my 2003 TPS mounted on an FC 65mm TB. I had to mount the TPS wires toward the front but I still had to use those same holes at 6 and 12 o'clock.
1 - 10 of 10 Posts
