1 - 14 of 14 Posts
WhiteSTguy
Well replaced my TPS sensor again on my SVT since it started running like crap. It bogs down when I hit the accelerater and just sounds like crap. After 2 days it is now starting to act up again. It only bogs on acceleration. I almost got stuck on a hill as the car just didn't want to rev or have a power.
Could there be anything else I should be looking out for that's crapping out my TPS sensors prematurely? My CEL just came back on but I'm sure that's just a oxygen sensor.
WhiteSTguy
Codes:
P0301 - misfire cylinder 1
P0303 - misfire cylinder 3
P0203 - fuel injecter circuit condition - injecter # 3
WhiteSTguy
Discussion Starter · #5 ·
Thanks man. I'm gonna do my fuel filter later today after work. I also didn't "hear" any vaccine leaks. I recently installed new plugs and just put on a new K&N filter. I will also cHeck my plugs and wires tonight too.
check the harness leading to the coil. they often fray and crack. a replacement pigtail is available to splice in, isnt expensive.
  • Like
Reactions: OrangeSVTguy
WhiteSTguy
Discussion Starter · #7 ·
OK I'll check that next. After changing the fuel filter, it ran "like new" again for about 10 minutes then it started running like crap again. Almost sounds like a lawn mower and misfiring and all that bullshit I guess [:(]
When I downshift and let it coast it seems to run smooth but once I hit the gas again it bogs and sounds like crap.
WhiteSTguy
Discussion Starter · #8 ·
maybe a vaccum leak or plugs/wires/coil
if none of those maybe the fuel pump...iono look at all the easys first
Hmmm... now that I think about it, when I changed my filter and started it up, I did remember hearing a noise coming from my gas tank while I crawling under my car and sounded like a high-pitched or whining kinda noise so now I'm wondering if it is my fuel pump....?
WhiteSTguy
Discussion Starter · #10 ·
Thanks Tom. A buddy had a nice scanner and just put it on this morning and it's saying my injecter #3 is stuck open. So I need to see what's going on with that. I wonder if they could be dirty/clogged and just run some FI cleaner or seafoam might help?
Oh believe me, I'll be buying your xcal/tune here when I can. Just trying to get some money saved up.
WhiteSTguy
Discussion Starter · #12 ·
Ran Some FI cleaner in my gas tank and half seafoam can in my oil and the other sucked up through a vacuume line.
She's driving like new again. Last up before winter I need to do my timing belt. I'm at 115k now [eek]
what it be like
sweet...i guess that stuff really works and yeah you better hurry up on that T belt rockauto sales some complete kits for pretty cheap
WhiteSTguy
Discussion Starter · #14 ·
I already bought the belt like 6 months ago haha
1 - 14 of 14 Posts
