Hi Guys
I'm helping a friend doing an engine valve replacement on a 2005 Focus II 1.4L and would like to hear some expert opinions re. the following -
i) Do you put in the new cylinder head bolts dry or would it be better to apply a bit of lubrication ? Haynes and the online Ford Workshop manual do not mention lubrication and I was wondering whether this is done deliberately to ensure the correct tightening torque.
http://workshop-manuals.com/ford/fo...dures/removal_and_installation/cylinder_head/
ii) According to Haynes, the new crankshaft pulley bolt (M12 x 29mm) needs to be torqued to 40Nm + 90deg. Reading some terrible stories about the bolt coming loose, I am having cold feet about this as I'm not sure if the recommended torque setting will produce enough clamp force to hold everything in place. As you know, the crankshaft / pulley assembly has no key so the bolt clamp force is your only grace here. The bolt itself is a 10.9 grade (and I think with a pitch of 1.75) which is supposed to withstand up to 126Nm of tightening torque. In addition, Ford's online manual gives a tightening torque of 45Nm + 90 deg which is confusing things even further. I'm also assuming that this bolt should be installed with dry thread and without any thread lock compound.
iii) My final question is about the new coolant pump that we just installed. Is it normal for it to be quite stiff to turn as the old one can rotate quite easily. The new pump is still dry so could it be that once it gets in contact with the OAT coolant, it will ease off ? I'm concerned that the resistance of the new pump would put additional load on the crankshaft pulley and therefore the pulley bolt.
Many thanks guys and as I said, would really appreciate your feedback.
Cheers
Cheers
