Everyone always asks about torque specs, the search column is full of them. So I figured since there is already a thread about the CEL's, why not one that has a fair amount of torque specs for everyone to use![headbang] These all come from the Chilton Manual, years 2000-2005. I will do my best to organize them accordingly. Everything will be in ft-lbs unless otherwise noted.
Tune-Up and Routine Maintenance
Wheel lug nuts
-2000 63
-2001+ 94
Spark plugs 108 in-lbs
Oil Pan Drain Plug 21
Manual Transaxle Drain Plug
-IB5 26
-MTX75 and MTX285 33
Manual Transaxle Speed Sensor Bolt 70-89 in-lbs
Automatic Transaxle Pan Bolts
-Models through 2004 62 in-lbs
-2005 95 in-lbs
2.0 SPI Engine
Camshaft Sprocket Bolt 77
Camshaft Position Sensor 180 in-lbs
Camshaft Thrust plate-to-head Bolts 89 in-lbs
Crankshaft Damper Bolt 88
Cylinder Head Bolts (in sequence)
-Step one 37
-Step two loosen half a turn
-Step three 37
-Step four tighten 1/4 turn
-Step five tighten 1/4 turn
Exhaust Manifold Nuts 20
Flywheel/Driveplate bolts 20
Intake Manifold Nuts
-Step one 120 in-lbs
-Step two tighten 1/4 turn
Oil Pan baffle bolts 18
Oil Pan to Block bolts 18
Oil Pump to Block Bolts 120 in-lbs
Oil Screen Bolts 89 in-lbs
Rocker Arm Bolts 18
Valve Cover Bolts 80 in-lbs
Timing Belt Tensioner Attaching Bolts 18
2.0L Zetec-E Engine (SVT INCLUDED)
Camshaft Bearing Cap Bolts
-Zetec
. -Stage One 89 in-lbs
. -Stage Two 168 in-lbs
-SVT
. -Stage Two 132 in-lbs
Camshaft Sprocket Bolts 50
Crankshaft Pulley Bolt 85
Crankshaft Rear Oil Seal Carrier Bolts 15
Cylinder Head bolts (in sequence)
-Stage One 132 in-lbs
-Stage Two 30
-Stage Three Angle-Tighten a further 90 degrees
Valve Cover Bolts 60 in-lbs
Exhaust Manifold Heat Shield Bolts 89 in-lbs
Exhaust Manifold Nuts and Bolts 144 in-lbs
Flywheel Bolts 83
Intake Manifold Nuts and Bolts 156 in-lbs
Lower Crankcase to Cylinder Block
-Zetec 16
-SVT 22
Oil Pick up Pipe Bolts 84 in-lbs
Oil Pump To Cylinder Block Bolts 88 in-lbs
Oil Pan to Lower Crankcase
-Stage One 53 in-lbs
-Stage Two 89 in-lbs
Spark Plug Cover Bolts (SVT) 88 in-lbs
Timing Belt Covers
-Lower Cover Bolts 60 in-lbs
-Middle Cover Bolts 37
-Upper Cover Bolts 89 in-lbs
Timing Belt Guide Pulley Bolt 17
Timing Belt Tensioner Bolt 18
Transaxle-to-Engine bolts 35
Variable Camshaft Timing Assembly
-Bolt to Camshaft 89
2.3L and 2005 2.0L Engines
Air Conditioning Compressor Mounting Bolts 18
Alternator Mounting Bolts 18
Auxiliary Drivebelt Idler Pulley 18
-Step One hand-tight
-Step Two 62 in-lbs
-Step Three 144 in-lbs
Camshaft Sprocket Bolts 48
Catalytic Converter Heat Shield Bolts 89 in-lbs
Catalytic Converter Nuts/Bolts 35
Catalytic Converter to Head Nuts 41
Water Pump Pulley Bolts 18
Water Pump Mounting Bolts 89 in-lbs
Crankshaft Pulley Bolts 85
Crankshaft Rear Oil Seal Carrier Bolts 89 in-lbs
Cylinder Head Bolts
-Step One 44 in-lbs
-Step Two 132 in-lbs
-Step Three 33
-Step Four Angle-tighten a further 90 Degrees
-Step Five Angle-tighten a further 90 Degrees
Valve Cover Bolts 89 in-lbs
Engine Mounts
- Transmission
. -Lower section 59
. - Center nut 98
. -Four Outer Nuts 35
-Right Hand Mounting Lower bracket 41
. -To body 35
. -To Engine 59
Transaxle Roll Restrictor 35
Flywheel Bolts
-Step One 37
-Step Two 50
-Step Three 83
Oil Pick Up Pipe Bolts 84 in-lbs
Oil Pressure Switch 132 in-lbs
Power Steering Pump Bracket Bolts 17
Spark Plugs 132 in-lbs
Starter Motor Mounting Bolts 18
Oil Pan-to-lower Crankcase
-Front Bolts 89 in-lbs
-Pan-to-Crankcase Bolts 18
Oil Pan to Bell Housing Bolts 35
Thermostat Housing 89 in-lbs
Timing Chain Cover
-8mm Bolts 89 in-lbs
-13mm Bolts 35
Timing Chain Tensioner Bolts 89 in-lbs
Transmission to Engine Bolts 35
Wheel lug nuts
-2000 63
-2001+ 94
-IB5 26
-2005 95 in-lbs
2.0 SPI Engine
-Step one 37
-Step three 37
Rocker Arm Bolts 18
-Zetec
-SVT
-Stage Two 30
Flywheel Bolts 83
-Zetec 16
-SVT 22
Timing Belt Covers
-Step Two 62 in-lbs
Cylinder Head Bolts
-Step One 44 in-lbs
-Step Three 33
Engine Mounts
- Transmission
. -Lower section 59
. - Center nut 98
. -To body 35
. -To Engine 59
Flywheel Bolts
-Step One 37
-Step Two 50
-Step Three 83
Timing Chain Cover
-13mm Bolts 35
