1 - 7 of 7 Posts
does anybody know wats the torque and sequence when you install a aluminum flywheel(fidanza)? im about to install one in my svt... i was lookin at this bulletin for OEM luk clutch and this is wat i found..
Torque all bolts in a star pattern to these specifications:• flywheel mounting bolts 83 ft-lb • clutch mounting bolts to 21 ft-lb• transaxle mounting bolts to 35 ft-lb
should i do the same on the aluminum flywheel?
OEM Luk clutch will not bolt to the fidanza. It is the TSB Clutch and is too big in diameter to bolt to the fidanza. I just tried this and I am now waiting on an Exedy clutch to come in.
Edit: The new Luk clutch kits are made to be used with the dual mass flywheel and it should come with one because the new disc is 9 7/16 or 9 7/8in in diameter i can't remember for sure which but the fidanza is made for a 9in clutch disc.
Nope and so far i can't find anything to fit the fidanza now. The exedy doesn't even fit it
1 - 7 of 7 Posts
