1 - 10 of 10 Posts
Just realised when doing a small top up to the oil in my 02 1.6V Focus this morning, about 200ml at the most, I'd put in the 15W/40 oil that was in the garage not the 5W30 that's in there – will this damage the engine at all?
Yeah definitely no more than that when the horrifying realisation struck that the bottle wasn't the 5W 30 it should've been, and the sense of panic that followed!
No need to panic, it's not like throwing the wrong kind of fluid in the wrong spot.
(We've seen it all, brake fluid in the P/S was one recent one - and NOT by the owner)
I'll move this to General Tech Chat for reference, you got a good answer right away.
Yep, you'll be fine until the next oil change. Even if you'd filled the whole thing up with 15w/40, you wouldn't self-destruct it. I had an old van that ran better on 20w/50 than the 5w/30 that was recommended for it. I did swap out for a thinner oil in the winter though.
I've used 15/40 since ive owned my car and ive put 60k+ on it so far.
Discussion Starter · #7 ·
Thanks for the responses all – interesting you've had no issues with the 15/40 Humphrey, was that all year round usage?
I have cause I just have and I live in Arkansas where where most of the time its 80+.
Right now its only dropping to around 25 at night.
I guess I could put in some thinner on the first as I need to replace my oil pan. Just wasn't looking forward to changing my oil just yet but I need to do the pan so yeahh.
I routinely started cars in Texas in the low 'teens using straight 30 weight for years. The cranking was slow but the engine ALWAYS started. I keep my batteries in good shape at all times though.
1 - 10 of 10 Posts
