1 - 4 of 4 Posts
I think our front and rear tires are different sizes. Is this a good or bad thing? And what size are they supposed to be?
Stock sizes are 185/65 14, 195/60 15 and 205/50 16.
Having different size tires is OK as long as the other tire on that axle is the same size. For example, you could technically run 195/60 15s on the rear and 205/50 16s on the front and there wouldn't be any drastic negative impact. If you had the same two tire sizes on the same axle you could be potentially putting yourself into a dangerous situation as the car would handle differently with a wider or taller tire on one side than the other.
Ah okay. Because I think the tires on the front are one size (they were replaced at the same time) and the back tires are a different size (on the car when we bought it)
1 - 4 of 4 Posts
