1 - 7 of 7 Posts
Can you swap tires from the left side of your car to the right side or are the tread patterns only meant to wear in one dirrection?
Meh.
If your tires are directional, no you can't swap sides. If they are not directional, than yes. Most tires will indicate right on them whether or not they are directional or or need to rotate in a certain direction.
What tires are on your car?
Old Phart
Moved to "Wheels & Tires".
^^^ Agreed
If the tread pattern is NOT symmetric, you'll likely see "rotation" and an arrow on the side to designate the proper mounting direction.
Some have different inside & outside patterns, these usually are NOT directional.
Kumo solus KH25. I didn't see any arrows, so I assume I could swap any tire to any position. Thanks for the reply.
1 - 7 of 7 Posts
