Geezer is 110% right, NEVER run your tires at max psi, or even anywhere near that number, ITS JUST NOT SAFE. The air pressure in the tires are set to the car, not the tire, because all tires do not have the same max psi rating, where this set might be max of 55psi, the next set might be 45psi, so the max psi will never be the same unless you buy the same tires all the time.
i would run about 36-38 psi in those tires, slight add in pressure will give you a little more protection for your rims, and give you a smooth enough ride a well. i say start around 36 and adjust as you need too but never run anywhere near the max psi rating
