I am pretty sure I will be able to get my new wheels come spring, maybe sooner. But, I have since learned that my tire selection (Toyo Proxie 4) has a problem with noise. I have also learned that the 'summer performance' tires are intended largely for dry surfaces. I need input plz on a tire (205/50/16) that performs well in the summer, but is also good on wet/rainy/flooded (as in hydroplaning potential) surfaces. It should be usable to ~40 degrees. A 'cool' looking tread pattern is a plus but not the primary consideration. I currently have the Pirilli P6 which I have no complaints with, but I also have no way to compare it to another tire type or brand. Oh! these are intended for the street only. My Focus is lowered 1.5" with a -1.3 camber in the rear.
Tire should be able to go 20K miles at a minimum before replacement is warrented.
Thanks!!!
Thanks!!!
