This guy has it right. I would also suggest (again) on having water depending on the weather. Constantly check your PSI as well. The pre-run walks definitely helped me. I also went slower on my first run. That was to make sure I had the course memorized. My Mk3 got 2nd place in the stock novice class the first time I went. Lost to an STI :/ but it was awesome and a great time!show up early.
have enough fuel.
pump up your tires to at least 40 psi.
bring lots of water/sunscreen, comfy shoes, etc.
don't be afraid to ask people for help or advise. they generally are all nice.
do lots of course walks to memorize the course (4 or 5). find an experienced driver and follow them, noting their line, or ask them their thoughts.
depending on if it is a competative event or not, often you can get ride alongs. its like a high speed course walk.
+2show up early.
have enough fuel.
I used the shoe polish on the tires when I did it years ago. Easy way to tell if you have the right pressure. Many good ideas here. It's lots of fun.If you've got an air compressor that plugs into the accessory outlet take it. That & a tire gauge are very useful....... I used to put stripes on the edge of the tires with that to tell how much they scrubbed on each run, helpful when setting tire pressures.
Believe me... Some guys drink beer at the track while waiting to jump into before the race... At least that happen hereWow that is so obvious it's almost stupid to even mention it. Almost.
