Thought I'd see if anyone else thought this isn't going to work right but here's what I'm up to:
2004 SVT Focus timing belt change. 113k miles, preventative maintenance. Runs fine, but I'm selling and more than a few have asked if the timing belt has been changed.
I have everything apart up to the point I take off the balancer and remove the old belt.
My first thought for improvising the alignment tool was to go to Home Depot and get the longest available M10-1.5 fully threaded bolt I could, which was 40 mm long. That turned out to be not long enough, so instead I'm using 1/4" drive extension.
For the cam alignment tool I'm using a 12" steel ruler, 6" would've worked okay but the cheapest option was the 12" combination square I bought. There was a 6" stainless steel ruler but that was thinner. 2 thicknesses of the ruler might be ideal, but I can eyeball centering it.
Whatever the result is, the old belt is worn but no obvious loss of teeth or anything. Probably stretched, and the new alignment should be better than the existing alignment.
Let me know if I'm off base... The $5 investment sits a lot better in my wallet than the $113 I found searching online for the FoMoCo tool, plus I couldn't figure out the right keyword search to find it on Fordparts.com.
