I'm in the process of making a custom build...and want to know more information, if anyone has it, about Ford TPS's, and how they work and are read by the computer.
Essentially, (without giving too much away and making this confusing) I'm wanting to use a throttle body and included tps from a different Ford. The connections are different, (TB is from a 90's thunderbird) but they are both 3-wire connectors. Will they both send the same type of signal to the ECU, I know the load sent to the ECU changes based on the position of the sensor, and I would assume that they should function the same, but I'm also not sure because I believe the Thunderbird used an OBDI, compared to the Foci OBDII.
Any feedback would be great. Thank you![ffrocks]
