1 - 4 of 4 Posts
I have a FC 65mm throttle body and havent had any problems.Make sure you take off the battery cable when you put it on so the computer can adjust to changing it.
make sure the tps is mounted right here is a diagram of how they should go depending on year and tranny. if your pedal is sticky, adjust the idle screw, it should just barely make contact with the plate
1 - 4 of 4 Posts
