I had purchased a ported throttle body from a member here. When I removed my original OEM one, I noticed a couple of things that I wanted to check with you guys first. Pictures are included for your reference. Please, excuse my lack of technical knowledge when I refer to some parts.
First and most important, when I removed the plastic shield I saw that there was throttle cable on the outside as expected. But where there is a post on the inside, nothing is connected. From the how to I used, there was another black, elongated piece connected there that ran parallel to the throttle cable. I have a yellow arrow pointing to the location. My vehicle is an 07 manual if that means anything? Pic below.
The second and final question I have; I used this time to clean out the air duct connecting the air box to the throttle body. There is minor carbon buildup within the duct but also oil within the tube (runs from engine to duct) and the inside of the duct (where tube connects). Is this normal or not and if not, what can be the cause of this so I can check into those causes also. Pics below.
Thanks everyone and happy new year!
