1 - 3 of 3 Posts
on an '03 zetec...is there a lil spring on the gas pedal for it? think im missing something to add a lil tension to this thing.
The cable might be stretched or loose. Follow the pedal up to the top and you should see something that you'll recognize. The throttle body has a wound spring on the shaft, but I'd think you'd be experiencing more than a sloppy feeling if that one was the cause. I'd still check it. Make sure the cable is clamped down on both ends as well.
There is a spring on the end of the cable. The cable goes thru the pedal and then the spring is after that.
1 - 3 of 3 Posts
