Thoughts on Poly Engine mounts?
546 2
Whats your guys thoughts on poly mounts? I have the dogbone of course w/ vf engineering DSM & getting ideas on which way to go for a PSM later on when I need to replace it.
1 - 3 of 3 Posts
Gave you a new thread for this one Bruce.
With the number of Mods. you have already you might want to give it a try.
Shouldn't vibrate as bad as a sacked stock one that's starting to touch metal on metal, won't be as smooth as going with a new stock one. Full VF setup instead of 2/3 would tighten it up & reduce wear on all of them. (reduce drivetrain movement/wheel hop with harder launch/driving)
w/ my magic bag
Thanx Roger. I was reading about all the motor mounts ppl were replacing & reseaching about. So later on I'd need to do the same for the psm. It might go for 6 months or a few more years, IDK. Same as the rear wheel bearings. Or the idler pulley bolt.
1 - 3 of 3 Posts
