Alright a buddy of mine gave me a stock dodge daytona turbo, I done a little research on this turbo and according to what I have read it is a t3 garrett with an internal waste gate set up at ~7.5psi. I'm looking to go shade tree on this project and kinda piece the kit together over the winter while my car is down. First question is, is this turbo even gonna work? I really only want to run 7 psi or lower for now until I can, learn more about what I am doing. I've owned a 90 talon tsi, and went all through that car so I am fairly familiar with a turbo car. I'm thinking of starting off with a manifold, mounting the turbo, then getting the charge piping fabricating that up, making a down pipe to run to my 2.5in flex then getting all the oil and coolant lines set up. Gonna run the coolant for the turbo off the heater core hose. With that kind of set up will I need to upgrade my injectors, and should I go with a blow through or suck through maf? I was thinking today and what if I used a cold air intake and instead of putting a filter on the end putting an elbow on and running that to my fmi? That would leave me with a blow through maf and I can have that taken care of with a tune, am I correct? The turbo has minimal shaft play, but if this one wont work out my buddy also has a tdo4 14b out of his eclipse, from when he went to a 16g, so if the t3 wont work out he is gonna give me the 14b. Any help is greatly appreciated I just don't want to blow something up.
