Anyone know where I can get a new catalytic converter for my 03 SVT? O2 sensors and converter went bad and the mech said that the new cat from ford will be $2000! I dont know why its so expensive but im looking for either a stock SVT converter or info on any performance or aftermarket converters that wont effect the performance at all. Any suggestions? Thanks
If the vehicle has less the 70k miles the cat and O2 sensors should still be under warranty according to the warranty guide.
From page 19:
WHAT IS COVERED?
The parts on the following list are covered by the Defects Warranties
that apply to every California 2003–model vehicle, regardless of the
GVWR* of the vehicle.
* Gross Vehicle Weight Rating
List of Parts Covered by Defects Warranties
• Air Flow Sensor
• Air/Fuel Feedback Control System and Sensors
• Air Induction System
• Altitude Compensation System
• Catalytic Converter
• Cold Start Enrichment System
• Controls for Deceleration
• Electronic Ignition System
• Exhaust Pipe (Manifold to Catalyst)
• Electronic Engine Control Sensors and Switches
• Evaporative Emission Control System
• Exhaust Gas Recirculation (EGR) System
• Exhaust Heat Control Valve
• Exhaust Manifold
• Fuel Filler Cap and Neck Restrictor
• Fuel Injection System
• Fuel Injector Supply Manifold
• Fuel Tank
• Idle Air Bypass Valve
• Ignition Coil and/or Control Module
• Intake Manifold
• Malfunction Indicator Lamp (MIL)/On-Board Diagnostic (OBD) System
• PCV System and Oil Filler Cap
• Powertrain Control Module
• Secondary Air Injection System
• Spark Control Components
• Spark Plugs and Ignition Wires
• Synchronizer Assembly
• Throttle Body Assembly (MFI)
