The Weight of the Interior
I personally have wanted to know what kind of gains I could get from reducing the amount of weight in my 2000 ZX3. A lot of people in this forum bash others for wanting to reduce the weight of their cars, but I say go for it. After a lot of searching and reading I decided to weigh some of the different things that can be pulled out of your car. I haven't pulled everything out yet, but I will update this as I do.
If you were wondering how much stuff weighs I will tell you. I bought a digital scale thats pretty darn accurate if I don't say so myself.
Here is a good forum post on HP/weight ratio and what you can expect from weight loss
http://www.focusfanatics.com/forum/showthread.php?s=&threadid=55914&perpage=12&pagenumber=1
In the rear:
Spare tire cover = 6lbs. 14oz.
Spare tire = 30lbs. 14oz.
Jack = 4lbs. 14oz.
Handle for the lugs = 1lbs. 9oz.
Cover for hatch area = 5lbs. 1oz.
All the plastic on the hatch inside = 4lbs. 10oz.
Plastic pieces covering rear shoulder seat belts:
1lb. 13oz. driver side
1lb. 14oz. passenger side
Rear shoulder seat belts combined = 3lbs. 10oz.
Side plastic panels next to back seat = 5lbs. each
Carpet on quarter panel in hatch:
1lb. 5oz. on the driver side
1lb. 8oz. on the passenger side
Pastic around rear side windows = 1lb. 1oz. each
Rear seat:
Bottom = 14lbs. 8oz.
Large back side = 24lbs. 8oz.
Small back side = 11lbs. 4oz.
Rear seat total = 50lbs. 4oz.
Rear Seat brackets and bolts = 4lbs. 5oz.
Stereo:
Aftermarket stereo = 4lbs.
Stock stereo = ???
Front seats:
Stock:
Upright part of seat = 18lbs.
Bottom part = 7lbs.
Plastic covers on seat belts combined = 1lb. 8oz.
Summit Racing plastic racing seats:
Seats = 11lbs. 4oz.
Seat covers = 2lbs.
Carpet:
1 piece carpet under front seats = 20lbs.
Door panels:
Door panel(not including padding stuck to door) = 7lbs. 13oz. each
Speakers = 1lb. 8oz. each
Bottom plastic door sills & plastic kick panels & the plastic piece in front of the console that's part of the dash combined = 2lbs.
Glove Box:
Glove Box = 2lbs. 9oz.
Cover under steering wheel:
Cover under steering wheel(where ODB II port is) = 3lbs.
Center Console:
Center Console = 3lbs.
15in. Wheels with P195/60/15 tire:
Stock:
15in. wheel with P195/60/15 tire = 34lbs.
Rota:
15in. Rota Slipstream with P195/60/15 tire = 31lbs.
Lug nuts:
Stock:
4 lug nuts = 8oz.
4 Tuner lugs that lock = 8oz.
Exhaust components:
Stock:
Exhaust manifold = 7lbs. 8oz.
Catalytic converter = 15lbs. 10oz.
Focus Central:
Race header = 11lbs. 1oz.
The Hood:
Stock = 28lbs. 10oz.
Carbon Fiber OEM from ZXTUNER.COM = 17lbs. 2oz.
The Battery:
Stock = 32lbs. 8oz.
Odyssee PC680 w/auto terminals = 14lbs. 8oz.
Weights done by ozan
Rear side windows ( hatchback with 2 doors) 2,6kg each : 5,73lb
Plexiglass for replacement : nearly 0,5kg each :1,1lb
rear window : coming soon
Passenger side airbag : 3,7kg : 8,15lb
Driver side : coming soon
rear window windshield stuff : 1kg : 2,205lb
Plexiglass for sunroof : 0,5kg : 1,1lb
This is all I have for now, but will update more later. I hope this is useful. Maybe it will keep everyone from asking the same qustions all the time.
In the rear:
Jack = 4lbs. 14oz.
Rear seat:
Stereo:
Stock stereo = ???
Front seats:
Stock:
Bottom part = 7lbs.
Seats = 11lbs. 4oz.
Seat covers = 2lbs.
Carpet:
Door panels:
Glove Box:
Center Console:
Stock:
Rota:
Lug nuts:
Stock:
4 lug nuts = 8oz.
Exhaust components:
Stock:
Focus Central:
The Hood:
The Battery:
Stock = 32lbs. 8oz.
