...but you probably knew that already.
Did you ever wonder why the temperature gauge gets to the halfway mark so quickly after you start the engine?
The gauge will hit the halfway mark with a coolant temp. of ~50C (122F). As the coolant temp. increases to normal operating temp. (~200F), the gauge won't move.
I don't know what the coolant temp. would have to be for the gauge to read significantly higher, but I imagine that it would start going up quickly when the coolant temp. gets above 210F or so.
The bottom line is that the temperature gauge is highly non-linear by design.
