Alright guys, I m replacing my drums. I'm using the method where you take the 30mm nut off and pull the drum off, not unbolting the 4 bolts holding the whole bearing assembly. I got the passenger side off no problem, slid right off. Now the driver's side is not coming off. I probably got 2+ hours trying to remove it..I took the 30mm nut off and started pulling. It wants to come off but won't. I even tried bolting the wheel on the drum with the nut off for more leverage. On the spindle it looks like something snapped off, like a head to a bolt. I read here (http://www.focusfanatics.com/forum/showthread.php?t=64923) there was a recall that put a 10mm bolt on the spindle to hold the nut on....Is this what it is? Did the former owner not know this and snap it off?
Any input would be appreciated!
