well a while ago some of you may remember i posted about a wierd sound when i let the clutch out...
well now it seems to just happen really freakin' randomly...
i should say i usually here it on start up but i hear it other times too just randomly....annoying!
its a deep groanish type of "squeal", but not really a squeal
sometimes its worse than other times...louder, or longer in duration
i was thinking wheel bearing possibly? so yesterday i took off all 4 wheels sprayed some wd-40 around the axle bolt...(middly of rotor) and also behind the rotor and hoped that it would seep in...
after that sound is still happening...maybe it just didnt help though?
also another annoying thing is that no matter what i do it seems like i cant get the sound to happen when i try to...ie i wanted to show a friend and it didnt happen...so basically its really hard to have someone stand outside and have them listen to where its coming from cause it doesntt happen consistently...but it does happen a lot...
what do you guys think...is their a way to test wheel bearing without tearing everything apart...or should it try and test other things?
thanks!
thanks!
