1 - 7 of 7 Posts
since i installed the Steeda SRI, i noticed when i floor it on the highway until i hit around 100..My temperature gauge meter will eventually drop down to about 30-40% and the car feels much faster. Normally driving the meter stays around 45-50% Is this normal and is it ok for the motor??
w/ my magic bag
If thats all you did....I wouldn't worry 'bout it then....
Found out it was my spark plugs. I was using the AR103s, which are one step colder. Using oem now and they're fine.
My car does the exact same thing it has since day one. To me it's a good thing it could overheat instead.
FF Affiliate
The Autolite AR103 are what you should be running , any one that has issues with them 99% of the time they gapped then and the gap is over .065-.070
The wire is cut back and you have to be VERY careful how you gap then , you dont gap them the same as a conventional plug
To gap them you have to think about you measuring the closes point from the wire to the closest point on the electrode , with the wire cut back you totally have to change how you gap these plugs
The gains from these plugs are well worth the extra 3-5 Min to gap them correctly
1 - 7 of 7 Posts
