1 - 20 of 24 Posts
it look's like you moved the brake light down into the reflector part of the taillight...right?
it kinda looks like this.
it looks to me, you added fog lamps(reverse and brake) in the diffuser.
Discussion Starter · #6 ·
DeadlyDean good eye brother. I've yet to see it done in the states at least. I've had the idea for a while now, but wasn't sure how to even do it. I only have the wiring left to do, but for that I may need some help i'm not much of an electrician. I am looking over the wiring how to for euro lights. Here's a better look at it.....
Discussion Starter · #9 ·
Now the only thing is i'm trying to figure out how I would wire in the lights. The reverse light on the car only uses a single wire? There are 2 wires a green and a black one on the foglight. How would that be wired?
is the brake light and the turn signal light one in the same for the original brake lights? if so, that is your problem... and you will have to get the signal from another source like your front turn signals. i think, i better go look at my car, haha.
Discussion Starter · #16 ·
No need. This is the how-to I ended up using and it worked[idea] !!! Thankyou Peterbilt[pray] . Time consuming but definitely worth it in the end.
http://olmikul.home.comcast.net/taillights.htm
I started to get confused with all the wires..... They are nicely tucked away now[neener] ! All in all I rate this 1 being the easiest 5 hardest, a 4. The hardest part was getting the circles cutout without a hole saw.[slap] Rotozip FTMFW[giggle] . lol. and figuring out how to mount the lights in such a compact space[gunfire] . The wiring wasn't too bad with the right how-to. I finally did what i've been saying for the past year and couldn't be happier.[woot] [wiggle] Now I think it's time for some [sleep] . [joke] I will probably waste the tank of gas I have just showing off... [rofl]
1 - 20 of 24 Posts
