1 - 6 of 6 Posts
Gan-San!
My brother and I are having the hardest time taking the damn thing off. It's just a simple wrench and pull right? Is there something I'm missing? Anyone know it's this hard? Like... we are not weak guys... but this making feel like I didn't eat my wheaties....
Gan-San!
Discussion Starter · #2 ·
I'm also wondering if I pull on it to hard, the steering rack will get damaged... true or false?
Removal
Loosen the front wheel nuts.
Remove the wheel.
Loosen the tie-rod end locknut and remove the retaining nut.
Loosen the locknut.
Remove the retaining nut.
Using the special tool, release the tie-rod end from the wheel knuckle.
NOTE: Make a note of the number of turns used to remove the tie-rod end.
Remove the tie-rod end and locknut.
Installation
WARNING: Install a new tie-rod end retaining nut. Failure to follow this instruction may result in personal injury.
NOTE: Make sure the tie-rod end is secured by the same number of turns used to remove it. After installation, check the toe adjustment.
To install, reverse the removal procedure.
Gan-San!
Discussion Starter · #5 ·
*note to self: You are a weak computer geek. When something doesn't move with a large wrench, call over a real man of the machines to move it.
My dad just called me a n00b. Really! I've been at this freak'n thing for hours and he comes home, gets on his back, puts his foot on the wheel well and yanks on the tie rod with a massively large monkey wrench. One shot, one kill... it moves. Talk about a blow to your manhood... lol.
Once I get the freak'n thing all put together, I'm going to Custom Alignment for all the adjustments so no worries about counting and all that.
Lol, so the problem was WEAKNESS....i see......JK glad you got it off finally i know i would get pissed. Good call on the Alignment.
1 - 6 of 6 Posts
