1 - 20 of 24 Posts
I want to swap out my cluster w/o tach to one with a tach. Which ones will fit the SPI? I have an 01'.
i might be wrong, but i believe its a plug n play type thing from any focus
atleast thats what it sounds like from the thread "the tach you never knew you had"
br/o/stang
I know theres a pin number difference between the duratec and zetec clusters (or at least the 05+?). Im pretty sure the spi/zetec clusters are interchangable
I swapped mine, and from what I found out by reading, clusters with a Tach on any foci from 2000-2004 should fit without any problems. THough I think the SVT ones dont fit.
BTW it is very easy to swap! 10 min max!
Buickboy is right. The clusters are interchangeable between the SPI and Zetec, except for the SVT cluster as louisgab mentioned. The Duratec's also use a different connector. I swapped out my cluster a few months ago for the KONA cluster. The KONA's are a safe bet because all of them are Zetec. I also prefer how they look over the standard cluster.
Jetsetter
yes plug and play, the only downside to this is that the cars mileage stays with the cluster, so if you want to do this you should find a cluster close to your current mileage, or less lol
and most dealerships wont program it for you, unless you buy it from them
The SVT one does fit the SPI i have one in mine and it looks great.
The SVT gauges go up to 160Mph and the standard focus clusters only go to 140Mph. I had heard that the SVT ECU was required for the speedometer to read the correct speed. But I guess that isn’t correct since you’re using one.
The speedo is off a little bit. When i'm showing 65 i'm really doing 60 but it's not to far off i just keep up with traffic.
with my stock spi cluster it shows im doing 65 when 2 different gps' says im doing 61-62...
It's probably due to your tire size compared to OEM.
You’re right. Tire size does cause a difference. Although, when I first got my focus, the speedometer was off by 2mph and it still had the stock 14" steel rims on it. So when I thought I was going 55mph I was actually going 53. Then when I put my 16" rim on it got worse. I think it’s off by like 4mph now.
yeah i know... thats why i use my garmin for a speedo, my gps and dads are off by most a couple tenths a mph, and my blackjack 2 is within half a mph of both. so i trust the gps most
true, GPS shows the most accurate speed, its satellite and more precise than a cluster.
1 - 20 of 24 Posts
