1 - 4 of 4 Posts
Has anyone used the tach driver when installing a tachometer? I got one and the instructions are kinda vague and don't help much. Do you have to connect it to the crankshaft positioning sensor or can you run it off pin 48 of the ECU?
if you have the reg zetec you can use pin 48. if you use the csps all you have to do is remove the battery box and you will see some wires coming out of the tranny. check the instructins from their, its stupid easy...
sorry did n't see with was spi,but the tranny should still be in the same spot
FF Cleaning Squad
He more than likly has a SPI since it was posted here but b/c of the SE status i could not honestly tell you if it is or not.
BUT
I belive you can just connect the wire to pin 48 on the SPI and it will work aswell.
1 - 4 of 4 Posts
