1 - 7 of 7 Posts
BodyKits=PantiesDrop
no you need a driver
someone was saying you can run a nitrous window switch off pin 42 on the ECU and that gives it a useable rpm signal so maybe that would work with a tach...i don't know which motor that was tho
Well I am running my Dynojet wideband controller off of the COP wire on the ecu and when I use their software it will show my my rpms. So thats why I asked. Someone should try to run their tach off of that wire and see if it works.
My=keyboard=is=messed=up.=No=spacebar!=Ill=keep=this=short.=Chhenscheid,=
before=you=install=aftermarket=tach,=do=a=search=on=the=OEM=cluster=swap.=Easy
to=do,=stock=look,=no=tach=driver=required.
1 - 7 of 7 Posts
