1 - 2 of 2 Posts
I have a spare new stat housing for my daughter's 2001 ZETEC. It will occasionally show a drop of coolant close to the front small hose. Looks like a straightforward R&R but how do you get the back small hose off? Maybe its easy to access with the housing pulled away from the engine? Already decided to swap it out - just need advice about the rear small hose. Thanks.
DTC P0606
^This. It's easier with the three bolts that hold the housing to the head removed. Then you can rotate the housing slightly, if necessary, to gain access to the hose clip ends.
You can remove the coil pack and bracket if you want but that's generally overkill.
1 - 2 of 2 Posts
