So the fofo started leaking coolant about a week ago and I finally got around to taking the thermostat housing off, because I couldn't find a leak anywhere else. I took a picture of the housing, and found what I BELIEVE is the culprit: a small chunk that is missing (at least I think something used to be there). So, I only have two questions:
1. Is that little notch that is missing causing the coolant leak, or is that little notch supposed to be there?
2. Do I need to replace the entire housing piece?
If someone could take a look at the picture and tell me whether I need to replace the entire part or just the o-ring that would be great. Any help is greatly appreciated.
Thanks. [thankyou]
Thanks. [thankyou]
