Just put in a new clutch and flywheel on my 2003 zx3 with the 2.3 engine and strolled into parts store and am informed that only ford stealerships sell the synthetic oil for my transmission ....sound right??
Stop spreading dis-info you have no clue what you are talking about this has been argued to death. the OEM ford honey is rated a 75w90 on FORDs own website go read for yourself, please stop spouting BS, Thanks!Be careful with that, GL-5 gear oils contain sulpher compounds that will attack yellow metals. For the money, I would just get the ford fluid.
Thank, heading out to the stealership soonShould only need two. They adjusted the capacity to 2.0 quarts so you wouldn't need that extra .1
This is still correct, the particular RP fluid mentioned is a special case in covering GL-5 standards with a GL-4 compatible fluid.Be careful with that, GL-5 gear oils contain sulpher compounds that will attack yellow metals.
You can actually find other non-ford sites talk about the ford stuff too, seems well received. OP, on the plus side, its a fluid that you will not be replacing again anytime soon. So think of it that way, its going to last and its known to be good.the Ford Honey (as it is known) is well worth it. Royal purple is about the same price, mights well go with what Ford recommends. There are lots of threads arguing the fact, but I love the Ford stuff
I am sorry, I am not familiar with this specific oil, however, if you can't understand my apprehension with using a gl-5 spec gear oil in a syncromesh transmission I don't know what to tell you. Although GL-5 gear oil is spec'ed for MT1(non-syncro) manual transmissions, common in heavy equipment, it is well documented that it has caused increased wear on syncros and other yellow metals. I only specified that I would exercise caution using a GL-5 oil for an MTX75. Oil weight is one thing, the additive package is an entirely different matter.Stop spreading dis-info you have no clue what you are talking about this has been argued to death. the OEM ford honey is rated a 75w90 on FORDs own website go read for yourself, please stop spouting BS, Thanks!
here https://www.fcsdchemicalsandlubrica... Full Synthetic Manual Transmission Fluid.pdf
here https://www.fcsdchemicalsandlubrica...ransmission Fluid&category=Transmission Fluid
The only reason Royal purple sometimes recommends their 10w40 motor oil for the trans is because of extreme cold weather but at operating temp the 75w90 and the 10w40 motor oil are the same on a viscosity scale. Down here in TX we really dont have a problem with extreme cold weather so 75w90 FTW
Max Gear is recommended for use in truck and automotive front or rear differentials, manual transmissions and lower gear units of marine engines that specify use of an API GL-5 or GL-4 fluid. It is non-corrosive to soft yellow metals (brass, bronze, copper, etc.) and synchronizer safe. Specially designed to extend gear and bearing life, Max Gear provides superior corrosion protection over competing conventional and synthetic gear oils.
We engineered this ultra-tough, high performance automotive hypoid gear oil to provide maximum protection to heavily loaded gears while maximizing power throughout the drive train. Max Gear outperforms ordinary gear oils by combining the highest quality synthetic oils with Royal Purple’s proprietary Synerlec® additive technology.
Max Gear makes gears run smoother, quieter, cooler and longer without overhauls. A direct reduction of drag in the drive train has huge advantage for trucks and other 4-wheel drive vehicles: better gas mileage. Max Gear is formulated with a friction modifier additive – no additional additives are necessary.
Max Gear is available in the following viscosities: 75W-90, 75W-140, 80W-90, 85W-140 and SAE 90
Max Gear High Performance Gear Oil Advantages
Maximizes horsepower
Extends gear and bearing life
Reduces operating temperature
Severe service performance
Lower coefficient of friction
Superior corrosion protection
Separates rapidly from water
Meets warranty requirements
Environmentally responsible
Formulated for limited-slip differential use
http://www.royalpurpleconsumer.com/products/max-gear/
From EXPERIENCE of using Redline MTL, Amsoil 75w90, RP Maxx Gear and Ford Honey
RP wins less notchy and much smoother shifts
Amsoil was closeto RP but RP overall felt better
Ford honey was Ok but notchy
Redline was worse than OEM ford Honey and red line now recommends their ATF fluid for the MTX.....
Thank you for the immediate biased response/opinion that everything I have to say is utter rubbish
The idea that 75-90 and 10-40 are the same viscosity is pretty goofy too. Simply and totally 100% incorrect.
The idea of some MTX using lightweight oils all the way down to ATF fluid has to do with improved gas mileage, the thicker 75-90 has lower mileage because of.........................increased viscosity.
Actually, it's not. Gear oil an motor oil conform to different scales. A 75W90 gear oil and a 10W40 motor oil are going to be roughly the same in terms of viscosity (obviously that doesn't mean they're interchangeable as the additive packs are completely different).The idea that 75-90 and 10-40 are the same viscosity is pretty goofy too. Simply and totally 100% incorrect.
Irony--it never goes out of style....'A 75W90 gear oil and a 10W40 motor oil are going to be roughly the same in terms of viscosity'
Nope and not even, I've done viscosity testing and ultimately it is based on how fast a fluid flows by weight and temp through a calibrated hole regardless of all the rubbish surrounding the subject. 40 weight oil will drain off an object faster to let the object corrode in storage from humidity, 90 NEVER will, so thick it stays on pretty much forever. They do NOT flow nearly the same at ALL. I've based storage of high quality expensive bare metal parts on that for 40 years.
As well I've run mechanical equipment using varied viscosities that overlapped the two, the higher number is ALWAYS thicker in the exact same oil with same additives. Gear oils are thicker to slow down throwoff of gears, it lowers wear. Used generally when there is no oil pump and splash only. Try pumping a 75-90 in an engine oil pump and see how long it lasts, it would be on bypass 100% of the time, maybe five minutes until it sheared the drive or tore up the pump. The engine would also self destruct from lack of oil, it is too thick to get quickly down the oil galleries. You'd fail connecting rods in minutes.
AND, that logic flies in the face of the OEMs using lighter weight oils in MTX all the way down to ATF (roughly 10 weight) in efforts to increase mileage. The extra viscosity is brought up countless times as in 'it doesn't shift as easy as before' with the heavier oils.
Some people need to pick up a book every once in a while......................it's all there.
Um..you're the one telling me to "go read a book", and yet you're completely ignoring the grading system of gear and motor oils. It's not "their chart", it's simply a depiction of the gear oil and motor oil grade scales.. There are plenty others out there, or you can just go to the published SAE papers. The first number refers to viscosity at 40C, the second number at 100C, both in gear oil and motor oil.Yes, whether or not synthetic can change the qualities of the oil.
Nowhere in there did I ever mention the oils use the same scale, but SAE designed them both and the idea pretty much the same.
I measured the viscosity of water with various chemicals in it for five years using a viscometer. Printing where the viscosity affected print quality and machine longevity. Water variances are much smaller than oil ones.
Speaking of irony............
'It's like saying 100F is hotter than 80C...'
Isn't that about the same as saying viscosity is the same or close with a temp rating difference of 60C? Or, the chart premise there. Goofy.
This is, or course, completely false. Viscosity improvers impact how little an oil thins as it heats up. The base oil determines the actual weight of the oil (the second number).10w-40 oil is actually a 10 weight with viscosity improvers,
Again, you don't seem to understand the concept of scale. The chart is actually quite clear--I suggest you give it another look: Kinematic Viscosity is at the left, at both 40C and 100C. At those various temperatures, you can see where an oil fits in its relative scale. For instance, a motor oil that is a 40W oil is between 12.5 to 16.3 cSt @ 100C; and a gear oil that is a 90W gear oil is between roughly 13 to 18.5 cSt at 100C. I'm not sure how the chart could be any more clear? Here's another may help:so how can a 90 be even close given the chart rules? And a 75 that is under a 10 would also be under a 75 as well according to the chart, one doesn't see anything wrong with that? An oxymoron if you ask me. The viscosity/temperature numbers at far right are clearly stated to be for mono grade oils ONLY and that means if you assume the 40 or 90 is for 10W-40's or 75w-90's upper end a mistake too. The higher numbers are not accurate, they are from viscosity improvers and not being a straight weight oil. or, the caveat about mono grade oils. Somebody making up the chart is talking out of both sides of his mouth at the same time. Why am I not surprised.
That's funny.All you have to do is read........................
Why would I do that? Again, the additive pack would likely damage the engine. Sure, some gear oils may also cause cavitation due to excessive foaming--but that's probably pretty unlikely. 20W50 is thicker than any 75W90 gear oil, but it' not going to cause damage to an engine (not saying it's optimal). Again, I wouldn't put 75W90 gear oil in a crankcase, but viscosity has absolutely zero to do with it.and I DARE you to put 75W-90 in an engine, the different additives be damned. The engine will cease to run long before the wrong additive package brings it down.
