1 - 3 of 3 Posts
I made the mistake of getting the Ford update for Sync in my 2014 SE. Version 4.6 installed and sadly it trashes SIRI function. It worked on version 4.3 before that but I cannot find any way to downgrade back to 4.3. Anyone had any success finding the older install files and forced Sync to install the downgrade?
If you register at ford.com, you can see the recalls for your VIN. You can also go to the Sync page and check to see if there is an update for your car. If there is you download the .zip file, extract the files, and copy them to a USB drive. Then you can plug the USB into the car, use the radio prompts to go through the update process in the car. My car was at Sync 4.3. The update was sync 4.6. Unfortunately i found out after the update that the new software version killed SIRI function.
1 - 3 of 3 Posts
