1 - 6 of 6 Posts
Hi again Foci Fanatics. I have another "can't figure how the heck to...." questions. For purposes of blutooth. Is there a way to change the name of the car to display on devices so it doesn't just say SYNC. I have multiple sync cars and so on my phone i have 2 sync connections and want to change to something identifiable.
Thanks again.
It might depend on your device. Have you tried to rename it under its BT connections? What device do you have?
I don't know if you have an option to do what you want. I think it should be in the OS and I don'T think you have access to it. The reason you ask is because having two cars with Sync/MFT, both running and you being out of them, may get on your phone both "Sync" connections. Right ?
Good Question, I actually just changed after reading, in my BB Torch, so I guess some Phones and OS's allow you to change as you need
I have htc desire hd but can't change in it. Can't rename "sync" when I do a blutooth scan so now my phone has 2 different "sync" connections in it. One for one car and one for the new one with no way to identify which is which. I have always seemed to be able to change what name shows up when searching for a device similar to how you create an SSID for your wifi network.
Guess no go.
Thanks
On Bluetooth connections select the device (SYNC) hit menu or options, must have the otion to change name
1 - 6 of 6 Posts
