Can anyone tell me where i can find my door lock relay or switch or fuse, the lock s trip back to unlock when locking. Its a 2001 se zetec focus sadan.
Lol that helpd alot but I took it to the dealership today to get my front shocks redone on the recall because they rusted through I had them go ahead and look at the locks.. they put a fuse in it blew as soon as they locked it... turns out there was a short in my hatch and a blown out motor in the passenger door.. probally all related...vrat_on_2k said:At driver's side, under the steering column you have to remove the plastic cover panel, then the two bolts and then press the tabs that holds the fuse panel to the metal frame. After it falls ... this little yellow thing is a 20 amp.
This is an imposible pic of the back of the fuse panel hope the tags can help you.
Now the main task is to find the reason for the blown fuse !
Good luck !
Im not sure what theyve done I get the car back tommorow afternoon.. im not sure if it was the lock or a short somewhere in the wiring..ZeDo said:Ahh Nice to know I am having the same issue lubed my door locks up and now my hatch doesn't work So with that info I'll go buy a new hatch lock. Did they put a new one in???
