*Climbs up on his soapbox*
1. A FRONT BAR is the best investment for handling you can make next to tires. People choose to do the rear bar more out of convenience (because it is easier to change), but are surprised when the handling characteristics become twitchy. Especially considering that these cars are prone to "lift induced snap oversteer". Lift out of the gas in a corner and you swap ends.
A FRONT BAR works to put POWER on the ground so that you can use the throttle more effectively. This is especially important on lower HP front wheel drive cars like the focus.
2. A REAR BAR often creates more issues than it solves. The rear of the car becomes more volatile and then there is the snap oversteer issue.
If...BIG IF you elect to do a rear sway bar upgrade, then absolutely upgrade the front. Otherwise, withe front being "soft" you create a pivot point that can't keep pace with the rear rotation.
3. The BEST set up (IMHO) is to put a larger bar in the front and LEAVE the rear STOCK. To facilitate MANAGEABLE oversteer, increase the spring rates in the rear.
For example, in the Grand Am Acuras and SCCA Acuras that we ran, the front springs were rated at 450LBS. The REAR were a whopping 1000 LBS. The rear sway bar was STOCK. Unlike a spring, the sway bar has little to no "give" and creates a sliding effect. Springs compress and TRAVEL vs. slide. This creates the same amount of oversteer (depending on spring rate), but allows the driver to better predict and point the movements of the car. A solid rear bar is more like a light switch. You know that the rear is going to come around, but that ties directly with the adhesion limits of the tire. Springs make this process more gradual and therefore more controlable.
*Climbs off of soapbox*
