1 - 20 of 21 Posts
Retired Focus Addict
I was just wondering what you all thought about the F2 rear sway bar... it something like 25.6mm or something... and then I was going to get the end links for the front... what do guys all think about them... like em or not???
Boost?
id personally buy the progress and be done with it, with a 25mm rear sway thew control arom tend to crack under the anned stress on non svt foci, the progress is a nice noticable upgrade and it wont break anything, plus its very reasonable at around $100.
OMGVTAK!
I wouldn't go with anything bigger than the Progress rear sway. We have one on the ST and ZX3 and love it[thumb]
I've never seen a Progress for under $100. Where'd you find one at that price BlackNRed?
The H&R bar is not too shabby either...
Discussion Starter · #5 ·
But doesn't the ST have the 21mm sway bar??? The progress one is only 1mm bigger... Don't think that would change that much over stock.
Focused Focus
Im running the 24mm H&R front and the 28.6 Steeda rear and the balance is unbelieveable.
i've got the 22mm progress, and i like it, it's good for the daily driver, who enjoys curves
Don't look at it as just 1mm as it will fool you....it can have dramatic impacts! You need to be looking at in cross sectional increase not just the increase in diameter. The 1 mm increase is less than a 5% increase in diameter but it is over a 10% increase when you calculate the sectional (circular) area of the bar.
sorry if this is a little off topic, but if you have sway bars and springs and you want the best handling, do you have then opposite?? hard springs with soft anti sways or vise versa. curious and what happens if they are the same??
Boost?
i believe i saw it for 100 at new edge durring a sale its like 120 now i think, havent looked in a while though already have a rear sway.
OMGVTAK!
It's a change, believe me. You can definitly feel it taking sharp turns. The Progress is great on a daily driver.
[thumb] I felt the difference my first run around the block. I'd never want to sell it.
Discussion Starter · #14 ·
so progress is the best to go with???
To achieve the best possible handling, you wanna stiffen the chassis of the car as much as possible. That's why stiff, mild-drop springs and shocks coupled with large sway bars are best. They help you control camber when cornering by reducing body roll. If you're cornering hard and the car is as balanced as it is when drving straight, the car will be able to stick a corner at the grip limit of the tire. A wider (not insanely wide) tire thats got a stiff sidewall construction will help cornering ability, as well as having the right camber setting (one that allows all of the tread section to contact the road surface under cornering). Performance bushings and at least for our Focasses better swaybar endlinks can polish off a very nice suspension setup. Then you can take off-ramps with Minis, Vettes, and Elises. [thumb]
A really stiff suspension (springs, sways, chassis, etc.) works really well on smooth roads such as a race track surface. As we all know, you don't find too many perfect roads in real life. The goal is to find a good compromise. That's why its very foolish to run a track setup on the street. Every expansion joint, rut, dip, hole will be causing sudden and unexpected lane changes and they will punish you physically. There's plenty of systems designed for the street that afford good handling and maintain reasonable ride quality.... stick with those.
Discussion Starter · #18 ·
ok the last question I should have about this before I make my mind up about it...
If I were to get the F2 rear sway which I think is something like 25-26mm in diameter what would be the downfalls to it???
Focused Focus
For the ? earlier^^^ Tein springs.
Discussion Starter · #20 ·
What do you mean I should get tein springs???
1 - 20 of 21 Posts
