1 - 2 of 2 Posts
Who makes the best? I've decided to start modding again so I want to shape up the weak points first. I just want aftermarket lowering springs, no coil overs. Should I just look for the thickest sway bar or is there a real show stopper out there? Thanks for the help.
Sent from my DROID X2 using Tapatalk
Sway bars are used to fine tune springs, therefore springs should be the first selection. Depending on the spring rates used you may find that you do not need sway bars or that the sways you may currently have are perfectly adequate. Usually only a small to moderate increase in bar size is all that is needed. Too large a sway bar can lead to severe oversteer issues. You want a neutral handling car. One were you can induce oversteer if and when desired. You don't want a bar making those decisions for you. there are lots of good springs out there. Good ones will meet (and state as such) ISO and/or TUV quality standards.
1 - 2 of 2 Posts
